Date/Time: Wed, 27 Nov 2024 00:35:48 +0000
SC Forex Data for RUB and CNH ?
View Count: 1307
[2014-03-24 01:06:24] |
AndyL - Posts: 119 |
Hello, is it possible to add USD/RUB, EUR/RUB (Russian Ruble) and USD/CNH (Chinese Yuan) to the Forex feed? These pairs are starting to become more common to be supported by FX brokers. Regards, Andy |
[2014-03-24 06:38:50] |
We tried these symbols on the FXCM FIX data feed and we do not get any data for them. They are rejected.
[2014-03-24 12:20:33] |
Pitty. I think Barchart would have these pairs.
[2014-06-28 20:08:21] |
Could you ask FXCM if they can stream these pairs on your fix connection? They do offer it on their trading platform(USD/CNH and USD/RUB). USD/CNH is already the 8th most traded pair according to the BIS survey. It would surely be good to have it.
[2014-06-28 21:51:45] |
We will check with FXCM.
[2014-06-29 07:20:38] |
USD/CNH and USD/RUB have been added from our side. USD/CNH is available now over FIX. USD/RUB is being added by FXCM to FIX. Please reply back in a couple of days to confirm these are working. At that time, we will check the data and make sure that Tick Size and Value Format are set correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-29 07:20:50
[2014-07-01 10:28:56] |
Hi, USD/CNH realtime data works. Historical chart backfill seems to work too, but intraday history does not seem to work(even for very recent data like today or yesterday). |
[2014-07-03 20:30:12] |
Looks like realtime updates for USDCNH stopped working, USDRUB also not streaming anything.
[2014-07-03 22:24:27] |
We notice on one of our servers, we are not getting the data from FXCM. Reconnect with File >> Disconnect and then Connect. FXCM has not made the USDRUB available yet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
