Date/Time: Fri, 28 Feb 2025 22:23:04 +0000
unabel to buy or sel on sim mode for last 2 hrs or so on ver2299 64
View Count: 449
[2021-09-03 16:49:05] |
User427561 - Posts: 217 |
applies to limit or stop orders, , was workin fine earlier morning on sim but stop pped a couple hrs ago taking orders . my end or yours ?
[2021-09-03 17:11:50] |
John - SC Support - Posts: 38289 |
Which type of Simulation are you using? Are you running Simulation Mode within the regular software, or are you using one of the Trading Evaluator options, and if so, which one (standard or Delayed)?
[2021-09-03 17:21:39] |
im using the normal sim mode on trade/sim plus it was working fne earlier stoppe a couple of hrs ago apllies to market orders too dome goes thro by/sell stops as if thry didnot exist!
Date Time Of Last Edit: 2021-09-03 17:33:08
[2021-09-03 17:38:08] |
opened an earlier versiom 2296 and it worked fine , seems somethining wrng with ver 2299
[2021-09-03 17:39:03] |
After you try to place an order open Trade >> Trade Service Log and see if there is a message in there as to what the issue may be. Refer to the following: Trading Information Windows: Trade Service Log For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
