Date/Time: Fri, 28 Feb 2025 21:39:30 +0000
Rithmic server
View Count: 644
[2021-09-03 16:12:06] |
User288300 - Posts: 7 |
Hi, Can you please add the Ritmic server: Rithmic paper trading.Chicago Area I would like to use my Leeloo account with Sierra Charts. Regards, Peter |
[2021-09-03 16:57:26] |
John - SC Support - Posts: 38282 |
It is up to Rithmic to add any servers. But the one you are specifying already exists in the list of servers for the new Rithmic connection: - Rithmic Paper Trading - Chicago Area - Non-Aggregated - Rithmic Paper Trading - Chicago Area - Aggregated For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-03 17:13:47] |
Hi Thank you for the fast reply: I sent a screencap I don't see it in the selection list. Maybe I choose the wrong main menu?
Private File |
[2021-09-03 17:36:07] |
That is the wrong Rithmic selection. You need to select the service named Rithmic Direct - DTC. Refer to the Setup Instructions here: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
