Date/Time: Wed, 14 Oct 2026 09:16:00 +0000
Market profile giving too many overnight days
View Count: 849
[2021-09-03 14:34:49]
User525965 - Posts: 180
Hi, I have my TPO to only show overnight for the last day but it keeps showing it for 2 days, but just on my ES and RTY charts. Doesn't do this for CL. I duplicated my settings for CL over to ES and it was correct for 1 day then today it start showing 2 overnight sessions again. How can I get rid of the 2nd overnight profile?
image2021-09-03_10-33-00.png / V - Attached On 2021-09-03 14:34:40 UTC - Size: 266.37 KB - 245 views
[2021-09-03 15:56:25]
John - SC Support - Posts: 48196
You just need to reload and recalculate the chart (Edit >> Reload and Recalculate). If the chart has been open this entire time, then it does not go back and remove/update prior information. Therefore, it would continue to accumulate both the day and evening sessions until there is a full recalculation of the chart.
[2021-09-03 16:03:50]
That worked, that's odd I just opened it this morning. Does it do that when I open the chart prior to the day session opening, that it shows the overnight 2 days back instead of just the current overnight session?
[2021-09-03 16:06:13]
It depends on the timing of when you opened the chart. It is possible that if you opened the chart before the beginning of the new day session, then it kept the previous evening session since you did not start a new day yet.
