Date/Time: Fri, 28 Feb 2025 21:58:15 +0000
Any news or timeline regarding live trading availability for AMP customers?
View Count: 586
[2021-09-02 22:54:15] |
User644837 - Posts: 9 |
Hi! If I am not wrong, it is not possible, currently, to use Sierra for live trading by an AMP account. Are there news regarding this issue, or have you now a timeline for that? Thanks. :-) |
[2021-09-03 12:41:19] |
Trading with AMP is supported. They use CQG: CQG Trading Platform Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-03 13:16:20] |
I apologize, my question was too vague. I am interested in trading CME, and I need as well server sided bracket orders. I understood that for that I would need the Sierra Chart Order Routing Service instead of CQG, and firm supporting TT order routing. I was thinking that currently AMP (no more listed in supported firm) was having problems with this implementation. Then I read here Sierra Chart / Trading Technologies Futures Order Routing Service "We expect this new direct routing to be start to become available in September 2021", and the new order routing, available as well in full for AMP, was what I was asking info about. |
[2021-09-03 15:50:38] |
John - SC Support - Posts: 38286 |
To begin with, you are correct that to have Server Side Bracket Orders you would need to use the Sierra Chart Order Routing Service (or the upcoming Direct Order Routing for the CME). Server Side Bracket Orders is not supported with CQG or Rithmic. You are also partially correct in that AMP is no longer supporting the Sierra Chart Order Routing Service. That stopped about seven months ago at their behest. It was due to an issue that occurred with TT, with whom this order routing service is setup. We are working on the new Direct CME Order Routing implementation, which is very similar to the Sierra Chart Order Routing Service, except that we are making the connections through the entire process and not using a third party (TT in the previous case). We are still working on this new implementation and the thread you reference is the place to get the information. We do not know if/when AMP will be supported. We are getting this working with one company first, then we will expand it out from there once we have everything working properly. We simply have not had the discussions with AMP yet regarding this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
