Date/Time: Tue, 22 Sep 2026 20:31:47 +0000
[User Discussion] - Buy Exit Code help
View Count: 4170
| [2014-03-23 18:07:41] |
| Litz - Posts: 135 |
This is incorrect something out of place. =OR(AND(CROSSFROMABOVE(AE3:AE5,AG3:AG5);AND(AA3<AB3,AA4>AB4)) trying to exit either cross 80 stochastics from above where AE is %K and AG is 80 line or Moving average cross down where AA and AB are moving averages http://www.sierrachart.com/image.php?l=1395598178297.png Friday ES chart Date Time Of Last Edit: 2014-03-23 18:10:50
| [2014-03-23 19:53:09] |
This should be written as: =OR(CROSSFROMABOVE(AE3:AE5,AG3:AG5), AND(AA3<AB3,AA4>AB4)) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-24 06:32:30
| [2014-03-23 20:46:59] |
| Litz - Posts: 135 |
I still get invalid formula message with that
| [2014-03-24 01:25:24] |
| Sawtooth - Posts: 4354 |
Try this: =OR(CROSSFROMABOVE(AE3:AE5,AG3:AG5) , AND(AA3<AB3,AA4>AB4)) |
| [2014-03-24 06:34:27] |
Yes, the formula given in post #4 is correct. We did not correctly edit the formula completely in our original post. It has now been corrected.
| [2014-03-28 23:57:38] |
| Litz - Posts: 135 |
Is this the correct format for entry when both conditions exist where %K AE crosses 25 AH line from below and fast moving average AA crosses up over longer moving average AB: =AND(CROSSFROMBELOW(AE3:AE5,AH3:AH5) , AND(AA3>AB3,AA4<AB4)) does not generate trade chart represents OR condition http://www.sierrachart.com/image.php?l=1396050558477.png =OR(CROSSFROMBELOW(AE3:AE5,AH3:AH5) , AND(AA3>AB3,AA4<AB4)) works Date Time Of Last Edit: 2014-03-29 00:03:34
| [2014-03-29 00:28:58] |
=AND(CROSSFROMBELOW(AE3:AE5,AH3:AH5),AA3>AB3,AA4<AB4) This formula says both crossovers must happen in the same bar to be TRUE. This would be rare. =OR(CROSSFROMBELOW(AE3:AE5,AH3:AH5),AND(AA3>AB3,AA4<AB4)) This formula says either crossover can trigger a TRUE. This is what the pic shows. Maybe you want something like this: OR(AND(CROSSFROMBELOW(AE3:AE5,AH3:AH5),AA3>AB3),AND(AE3>AH5,AA3>AB3,AA4<AB4)) This formula is TRUE when: AE3 crosses AH5 from below and AA3 is already above AB3, OR AE3 is already above AH5 and AA3 crosses AB3 from below. |
| [2014-03-29 01:19:11] |
| Litz - Posts: 135 |
OK Tom thanks that works better
| [2014-03-30 21:31:27] |
| Litz - Posts: 135 |
tomglib , this is what I came up with to solve the problem of preventing buys while longer term MA is still going down: =OR(AND(CROSSFROMBELOW(AE3:AE5,AH3:AH5 ), AE3>AH5,AB3>AB5) , AND(AE3>AH5,AA3>AB3,AA4<AB4)) K =OR(AND(CROSSFROMABOVE(AE3:AE5,AG3:AG5),AA3<AB3),AND(AE3<AG5,AA3<AB3,AA4>AB4)) M seems ok with input and range bar tweaks Now looking to include Stochastic divergence above 80 or below 20 to improve entries Divergence is a good reversal sign http://www.tradeforextrading.com/index.php/stochastic/stochastic-divergence-trading IE if %K decreases after crossing above 80 while price increases, sell if short term ma reverses from friday ES example of divergence http://www.sierrachart.com/image.php?l=1396215671106.png playing with these: if %K decreases after cross above 8o, and price increases, buy when %K crosses 80 =OR(AND(CROSSFROMABOVE(AE3:AE5,AG3:AG5),AA3<AB3),AND(AE3<AG5,AA3<AB3,AA4>AB4) , AND(AE3>AG3,AE3>AE5) , AND (AA3<AA5,AE3<AG3)) conversly If %K increases after crossing below 20 while price decreases, buy when %K crosses above 20 =OR(AND(CROSSFROMABOVE(AE3:AE5,AG3:AG5),AA3<AB3),AND(AE3<AG5,AA3<AB3,AA4>AB4) , AND(AE3<AH3,AE3>AE5) , AND (AA3>AE5,AE3>AH3)) still learning Date Time Of Last Edit: 2014-03-30 21:41:49
