Date/Time: Fri, 28 Feb 2025 18:16:16 +0000
Rithmic
View Count: 516
[2021-09-02 16:14:37]
Yogi Bear - Posts: 2
Thanks for the answer but is there a possibility that I can use my Rhythmic Data Fed for the Eurex (FDAX, FGBL) because I already paid for that Data Feed.
kind regards
joerg
[2021-09-02 18:10:14]
John - SC Support - Posts: 38280
To use EUREX from another vendor, you need to be on Package 10 or higher. Refer to the information here:
July 1, 2021: EUREX Realtime Data from Denali Exchange Data Feed Policy
We have gone ahead and set your account to evaluate Package 12 for the next 30 days. Therefore, you do need to do anything further, and you will be able to receive the EUREX data from CQG. Just keep in mind that at the end of the 30 days, you will want to change your Service Package to Package 11 (equivalent of Package 5).
