Date/Time: Tue, 17 Nov 2026 00:30:22 +0000
[User Discussion] - Can't connect Sierra to transact
View Count: 712
[2021-09-02 16:14:14]
User202129 - Posts: 7
Hi
I can't connect Sierra chart to Transact.
I did everything you mentioned on your website.
Please try to solve it.
Thank you
[2021-09-02 18:05:30]
John - SC Support - Posts: 48547
First, make sure you have gone through the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions
If you have done all that, and you are still having a problem, then we need to know the exact message you are getting, or problem you are having.
Date Time Of Last Edit: 2021-09-02 18:05:44
[2021-09-02 18:15:34]
I did it all again now.
It doesn't work.
Can anyone remote control me?
[2021-09-02 18:51:14]
What is the exact message you are getting, or what is happening.
[2021-09-02 18:58:58]
File attached
image‏‏מצגת של Microsoft PowerPoint חדש.jpg / V - Attached On 2021-09-02 18:57:12 UTC - Size: 63.2 KB - 299 views
[2021-09-02 18:59:26]
I attached a jpg of the message
[2021-09-02 19:13:14]
Refer to the following for what that error means:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError
