Date/Time: Fri, 28 Feb 2025 18:29:11 +0000
ServerSide OCO
View Count: 722
[2021-09-02 16:10:42]
User403758 - Posts: 25
OK. Last Question: I am looking forward to book SP11. I think I have to book exchange services via SC as well. Ok.
But what do I have to do in order to route (serverside OCO) Orders via SC Data Feed to AMP?
Thanx
[2021-09-02 17:52:37]
John - SC Support - Posts: 38280
Make sure you follow through all the Setup Instructions for the exchanges that you want from the Denali Exchange Data Feed. You will find the link to each section of the Instructions (CME Group, EUREX, CFE) at the top of this page:
Most likely, AMP has set you up with CQG for your order routing. If this is the case, then you will follow these instructions to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
And then go through these instructions just to ensure that everything is setup properly to get your data from us and route your orders to CQG/AMP:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
