Date/Time: Fri, 28 Feb 2025 18:32:16 +0000
numbers bars problem
View Count: 366
[2021-09-02 15:15:46]
User278398 - Posts: 291
hello
i read somewhere that i can't see your footprint "numbers bars" if i use my broker interactive brokers.
i connect him and i see it properly.
do you fix the problem? or it is still not good ? (as you can see in the attach pic, it is look good)
regards
imageorgolan111111.jpg / V - Attached On 2021-09-02 15:10:35 UTC - Size: 484.64 KB - 169 views
[2021-09-02 17:02:24]
John - SC Support - Posts: 38280
We have seen problems with the data from various vendors when it comes to good handling of the Bid and Ask data at the per trade level. If it works for you, then that is great. But overall we know that with the Denali Exchange Data Feed that you will have the proper data and not have issues, which is why we recommend using it.
