Date/Time: Mon, 05 Oct 2026 10:08:18 +0000
Market depth
View Count: 647
| [2021-09-02 14:56:24] |
| AKR - Posts: 542 |
Is there a way that when data (text, colors, etc) from the market depth histo crosses other info from the chart (like bar, or colors from eg. number bars) that then the market depth is not shown for that "columns/cells".? I guess not, but would be awesome feature. eg. see screenshot |
| [2021-09-02 16:51:30] |
| John - SC Support - Posts: 48095 |
There is not a way to do specifically what you are asking. But you want to ensure that the drawing of the Market Depth is the lowest priority . To do this, make sure it is listed near the top of the Studies window. Refer to the following for more information: Chart Studies: Study Display Order For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
