Date/Time: Fri, 28 Feb 2025 18:50:36 +0000
*** Need help with SC issues
View Count: 589
[2021-09-02 14:48:57] |
User922418 - Posts: 13 |
I am using Denali data feed. Don't know why this happens, but it is driving me crazy. Would GREATLY appreciate the help because I am at my wits end! When I go into studies, and modify anything in there, and click on the 'OK' it is PAINFULLY SLOW for SC to react to my request. In fact, even right clicking on a chart is painfully slow waiting for the menu screen to appear. Also, when it finally accepts the OK key being pressed, the hour class shows up and takes several seconds to update the chart and the entire SC main window jumps. DRIVING ME CRAZY. Would appreciate a quick reply from a mod. Thank you |
[2021-09-02 16:49:26] |
John - SC Support - Posts: 38280 |
Refer to the information here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
