Date/Time: Fri, 28 Feb 2025 18:20:27 +0000
Which service package to get?
View Count: 352
[2021-09-02 14:31:43] |
User102795 - Posts: 1 |
My trading account is not yet funded, but I would like to continue with using Sierra chart to practice simulated trading in the next few weeks. Which service package do I get?
[2021-09-02 16:25:45] |
John - SC Support - Posts: 38280 |
It just depends on what you need for your trading style. Refer to the difference between Package 3 (Standard) and 5 (Advanced) on this page: Description of Service Packages and Pricing: Packages You do not need Packages 10 or 11, as those are only if you are going to use the Denali Exchange Data Feed, and at this point we recommend using the Delayed Exchange Data Feed, as it gives you the data from the CME Group and EUREX at no extra cost and acts like real-time data, just delayed by 10-15 minutes. Refer to the following: Delayed Exchange Data Feed There is also Package 12, which includes the MBO data, which does work with the Delayed Streaming Data, but it is a pricey option at this point. But it is up to you. For more information on MBO, refer to the following: Market By Order Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
