Date/Time: Fri, 28 Feb 2025 21:53:31 +0000
[User Discussion] - DAILY OHLC lines from previous day
View Count: 652
[2021-09-02 12:28:26]
58LesPaul - Posts: 429
I’m labeling this a User Discussion because SC has tagged me for too many support requests.
I use Daily OHLC study to plot the high and low from the last 3 days and I only want them plotted on the current day. Everything worked fine up until about a Month or so ago when I updated to a new release. Now the lines stay on the charts for the previous day. I have to go to each chart, open the study window and click OK, then the high and low lines on the previous day disappear. I have to do this to 9 different charts. I assume it was something SC changed on a new release because I asked about it before and they deleted my post.
My question for other users, is there anyway to accomplish this without going to each chart, opening and then closing the the study window?
[2021-09-02 17:42:14]
User90125 - Posts: 715
Try going back to the release where it worked for you.
Find the .cpp file with your then-working Daily OHLC study.
Copy it to a new name and then compile a new .dll yourself.
Then run it and see if it works the way you think it should.
[2021-09-02 18:56:59]
Not exactly sure what you are saying?
Are you saying after I compile a new .dll, which would be the old Daily OHLC study, try running it on the latest software release? Are you assuming SC changed the code in the Daily OHLC study to react this way? I just figured they changed something in the program and it caused the study to react this way. But I know nothing about software or compiling dll’s or any of that.
Thanks anyway
Date Time Of Last Edit: 2021-09-03 00:23:22
[2021-09-03 02:32:25]
Welcome.
Maybe SC will be along to help you, or you can see if a programmer like Ackin would be able to fix it for you.
