Date/Time: Fri, 28 Feb 2025 18:20:52 +0000
FCE delay
View Count: 443
[2021-09-02 10:31:04]
karaamohamed - Posts: 7
I have the Denali 11 package at 36 USD. And I have the Data CQG. However I trade FCE and there is a delay. How can I get it in real time? I do not have the order book on the FCE either, while on EUREX I have it.
imageCapture.PNG / V - Attached On 2021-09-02 10:30:50 UTC - Size: 382.59 KB - 165 views
[2021-09-02 10:58:14]
What is FCE?
[2021-09-02 14:13:02]
I need to have real time feeds without having an account with a futures broker, I need the euronext, eurex, cme, cfe (vix), cbot, what should I take as a subscription please?
[2021-09-02 16:15:17]
John - SC Support - Posts: 38280
The EUREX and CFE are part of the Denali Exchange Data Feed and do not require a brokerage account. Therefore, just follow these instructions to get setup for these exchanges. First for the EUREX, go through the following:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX
And then for CFE go through these instructions:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_CFE
The CME and CBOT (and NYMEX and COMEX if you want those as well) are also part of the Denali Exchange Data Feed, but due to CME Rules, they require that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees. If you just wan to pay the Professional Rates, then follow these instructions and be sure to fill out the agreements as a professional:
Otherwise, if you want to get the non-professional exchange rates, then you would need to have a brokerage account. There are some low-cost options available, which you can find out about at the following link:
Easy Solution to CME Funded Trading Account Requirement
For EURONEXT data, you would need to use the Sierra Chart Exchange Data Feed and enable the appropriate exchange(s) ("Euronext Futures Indices" and/or "Euronext Futures Commodities"). Refer to the Setup Instructions for the Sierra Chart Exchange Data Feed here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
