Date/Time: Fri, 28 Feb 2025 18:22:51 +0000
TopStep-pls be specific
View Count: 558
[2021-09-02 10:29:17] |
User968625 - Posts: 260 |
Hello, I have seen the in link below and I am making a new one to make sure you see it in time (Key to connect Topstep Trader) I am having a 30 mins call with TopStep. It seems that you are saying in the post , as per link, that you are ready and no work needed by SC. Is this the case? What is needed then? I need specifics pls so we can all move forward with that. Thank you |
[2021-09-02 15:30:44] |
John - SC Support - Posts: 38280 |
We are not sure what you are looking for, but here is what we can tell you. There is a new interface that has been created by Rithmic that is now working and available. In order to use this new interface, you will follow the setup instructions here: Rithmic Trading Platform Service: Setup Instructions We have heard of a lack of historical data when using this interface, and in general we recommend using the Denali Exchange Data Feed for your data with Sierra Chart. Refer to the information on this page: Denali Exchange Data Feed With regards to the data, just be aware of the requirement of the CME Group regarding the need to have a live, funded, futures trading account in order to get the data at the non-professional rate. The connection to TopStep does not count towards this requirement. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
