Date/Time: Fri, 28 Feb 2025 18:21:13 +0000
CME Solution with AMP
View Count: 609
[2021-09-02 08:22:40] |
User120666 - Posts: 46 |
Easy Solution to CME Funded Trading Account Requirement On this solution link it says an AMP account with $100, but here on AMP it says $500 minimum: https://application.ampclearing.com/account/login.aspx?ReturnUrl=%2fapply Do I need to deposit $500 or just $100? I have no plans to use the account (just for the data solution, per your instructions), so I don't want to have to deposit a minimum of $500. Is there a workaround please? |
[2021-09-02 09:01:37] |
Try Stage 5 with 200USD. Also ask AMP about their minimum.
