Date/Time: Fri, 28 Feb 2025 18:17:45 +0000
bug posQty@price
View Count: 392
[2021-09-01 16:50:26] |
RD877004 - Posts: 1 |
bonjour, J'ai un problème avec sur le BTCUSD_PERP_BINANCE impossible de placer un ordre merci de mettre à 0 ( reset). Merci d'avance Date Time Of Last Edit: 2021-09-01 16:50:51
[2021-09-01 19:11:25] |
John - SC Support - Posts: 38280 |
From Google Translate: Hello,
I have a problem with on the BTCUSD_PERP_BINANCE impossible to place an order please set to 0 (reset). thanks in advance We do not have a trading connection to Binance, so it is not possible to place trades directly from Sierra Chart to Binance. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
