Date/Time: Tue, 26 Nov 2024 00:54:50 +0000
2 Monitors: One SC instance or two
View Count: 1112
[2014-03-23 06:18:27] |
tobi - Posts: 351 |
Dear SC team, with regard to performance (not handling) which system setup would you recommend? Using 2 monitors 1. Two SC instances, one on each screen, with one chartbook open in each instance. Each chartbook contains 16 charts (8 open/visible, 8 minimized) 2. One SC instance across both screens with one chartbook. Then this chartbook would contain 32 charts (16 open/visible, 16 minimized) |
[2014-03-23 07:03:07] |
We recommend 1.
