Date/Time: Fri, 28 Feb 2025 18:09:43 +0000
CANT SEE ALL DATA NUMBERS BARS STUDY
View Count: 440
[2021-09-01 12:18:42]
User278398 - Posts: 291
i just connect to your program.
i attached a pic that described my problem.
i cant see data from 10:02 last day (i can see only before this).
what to do to fix it?
regards
imageORGOLAN.jpg / V - Attached On 2021-09-01 12:13:53 UTC - Size: 348.72 KB - 135 views
[2021-09-01 13:30:08]
John - SC Support - Posts: 38280
You need to try redownloading the data from before the issue starts. Refer to the following:
