Date/Time: Fri, 28 Feb 2025 18:48:23 +0000
Possibility to display the ticks subtracted from the commission
View Count: 398
[2021-09-01 09:47:32] |
AC109756 - Posts: 18 |
Hello, Is it possible to display the PNL minus the commission in this window (see attached image). I can see it in the "Trade Activity Log" window but not in this window. Thank you. |
[2021-09-01 13:13:02] |
John - SC Support - Posts: 38280 |
Refer to this setting: Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
