Date/Time: Fri, 28 Feb 2025 18:33:24 +0000
Package 11 with Denali - EUREX doesn't work
View Count: 582
[2021-09-01 07:28:21] |
User330092 - Posts: 9 |
Hello, With new month, Eurex stop working. "Symbol -1 unknown". Balance and Denali for Eurex is active. Could you help me? |
[2021-09-01 08:00:19] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-01 12:26:12] |
User163504 - Posts: 10 |
Hello, I have the same issue. Since this morning I cannot load the data in the Chart of the Future F.US.DSXU21, please refer to attachment ! The symbol F.US.DSXU21 is available in the Chart Settings so I do not understand what is required. Why is the current Future Contract F.US.DSXU21 not continueing for September ? All other Sierra Chart user of my trading community do not have this issue ! How can I solve this issue asap ? Best regards Anh Tran Quoc |
[2021-09-01 12:48:11] |
In the case to post #3, you need to complete the EUREX agreements here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements_EUREX And then activate the exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedEUREX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-01 13:08:29] |
Thanks for the quick input. But why do I have to sign again and do I have to repeat this procedure every month? |
[2021-09-01 13:40:56] |
John - SC Support - Posts: 38280 |
You do not need to repeat the process. You had never signed the agreements for the EUREX (you had previously signed agreements for the CME Group data).
