Date/Time: Fri, 28 Feb 2025 18:06:20 +0000
Different between Bid+Ask vol with total Volume
View Count: 579
[2021-08-31 16:08:43] |
User946060 - Posts: 2 |
Hi, I have seen that Ask+Bid volume does not equal total Volume in 5m chart - 26x12 154 - 20x14 263 - 23x19 316 ... I have also attached file for detail. How can that happen? I would like to understand that. Thank you. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=54253 |
[2021-08-31 17:19:56] |
John - SC Support - Posts: 38280 |
You need to expand your window some more, or decrease your font. You are missing the display of a digit in at least one of the numbers.
For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-31 17:20:10
[2021-08-31 17:37:43] |
You need to expand your window some more, or decrease your font. You are missing a digit in at least one of the numbers. Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-09-01 01:26:36] |
Yes, my fault. It's ok now. Thanks John! Date Time Of Last Edit: 2021-09-01 01:26:51
