Date/Time: Tue, 26 Nov 2024 07:00:15 +0000
daily charts data on SC service
View Count: 1096
[2014-03-22 16:22:22] |
cmb999 - Posts: 211 |
for some reason, latest daily bar on ag futures, e.g. ZC or ZW (May) have strange high value as of late,
Date Time Of Last Edit: 2014-03-22 16:28:36
[2014-03-22 21:52:07] |
Refer to help topic 2: http://www.sierrachart.com/index.php?l=doc/helpdetails2.html We see no obvious problems with the historical data for those markets and delivery month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-22 21:52:42
[2014-04-23 22:36:06] |
this is happening everyday in 6J contract, for example. the next day, the prior day's error is corrected. low price has two extra 0' s inserted : 0.9757 --> 0.009757 |
[2014-04-24 00:04:42] |
User12676 - Posts: 70 |
I certainly see the problem, and Im tired of having it. Please fix. With ZC ZS and ZW all on historical daily have incorrect data. Price goes up on an order of magnitude. |
[2014-04-24 00:18:46] |
I certainly see the problem, and Im tired of having it. Please fix. No. Your problem is unrelated to this. Please do not make postings about this in a thread that you did not start. It takes more of our time to respond, you are confusing the user and others with this. Sierra Chart works with a wide array of services with a wide array of data sources. This is unrelated.
With ZC ZS and ZW all on historical daily have incorrect data. Price goes up on an order of magnitude. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-24 00:19:52] |
low price has two extra 0' s inserted : 0.9757 --> 0.009757 Post an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image And let us know what Data or Trading service you are using Sierra Chart with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-24 01:36:05] |
getting, HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-04-23 21:33:46 |
[2014-04-24 02:12:35] |
data from SC. trading with CQG fix http://www.sierrachart.com/image.php?l=1398305495892.png Date Time Of Last Edit: 2014-04-24 02:13:45
[2014-04-24 03:45:13] |
Update the Symbol Settings and apply them to the chart following the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
