Date/Time: Fri, 11 Sep 2026 02:38:11 +0000
Is viewing the day session for Micros possible? OR Is your software malfunctioning?
View Count: 900
[2021-08-31 03:52:08]
User606730 - Posts: 3
I want to view the "day session" only for the micro MNQU1. Under chart setting: I have "Evening/Full session" UNCHECKED but your chart still gives me the full 24 hr session.
The normal contract NQU1 works properly. (It will allow me to choose day session or full session.)
Is viewing only the "day session" possible for the MNQU1? ...OR Is your software malfunctioning?
[2021-08-31 10:22:16]
This is all explained on this page here:
Historical Chart Prices
The above response was based on the understanding that you are referring to a Historical Daily chart.
Date Time Of Last Edit: 2021-08-31 18:32:18
[2021-08-31 14:31:36]
I looked on the link that you sent me. I do not see the answer. Just to be clear: I understand how to do this in a normal contract. I've been using Sierra Charts for 10 yrs, and I never had a problem with it working properly.
I know that you go to the CHART heading at the top of the chart and check or uncheck "Use Evening/Full Session".) See attached screen shot.
However, I am trying to trade a micro contract for the first time ( MNQU1 ) and checking or unchecking "Use Evening/Full Session" does nothing. It stays on full session either way.
imageScreenshot (186).png / V - Attached On 2021-08-31 14:26:59 UTC - Size: 132.09 KB - 287 views
[2021-08-31 16:39:49]
John - SC Support - Posts: 47841
What are your Session Times set to (Chart >> Chart Settings)?
[2021-08-31 18:20:13]
Ok. I see the problem. When I duplicate a chart in MNQU1, it does not keep my session times. It reverts the times back to the default. When I duplicate a chart in the NQU1, it keep the same session times.
Why is that?
[2021-08-31 19:24:38]
Refer to the following:
Global Symbol Settings: Preventing the Changing of Intraday Chart Session Times
