Date/Time: Fri, 28 Feb 2025 18:50:01 +0000
Reactivating With a New AMP Joint Account
View Count: 567
[2021-08-31 03:03:09] |
User297050 - Posts: 51 |
I have opened a new Joint Account with AMP Futures and want to use Sierra Charts with the new account. My Sign on with SC Support Board contains my original account number with AMP. Will that still remain my sign-on for Sierra and if so I can add funds to my Sierra Account. My question is then how do I coordinate and apply my Sierra Charts to my new AMP Account.
[2021-08-31 15:33:07] |
John - SC Support - Posts: 38280 |
There is no connection between your Sierra Chart Account Name and your AMP account. It is just a name, and it was one that AMP chose for you when you signed up with them at that time. In order to connect to the account you want, you just have to enter the proper CQG credentials in the Data/Trade Service Settings. If you did not get new credentials, and your new account is under the same CQG credentials as your old account, then refer to the following for how to select your Trading Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
