Date/Time: Fri, 28 Feb 2025 18:39:54 +0000
Numbers Bars: Possible to calculate Maximum Ask Volume Bid Volume Difference in ACSIL/code
View Count: 775
[2021-08-30 18:49:47] |
User719512 - Posts: 299 |
Is it possible to calculate Maximum Ask Volume Bid Volume Difference in ACSIL/code? For most all numbers bars subgraphs, one can calculate these values in ACSIL/code and not rely on the user adding a NBCV study to their chart and having our study then reference that study/subgraphs. Being able to calculate NBCV SG8/SG9 would then allow us to also calculate SG28/29. If this is not possible today, can Sierra expose these values as a "sc." property/method? Thank you! |
[2021-08-30 20:25:08] |
User907968 - Posts: 833 |
sc.BaseData[SC_ASKBID_DIFF_HIGH] sc.BaseData[SC_ASKBID_DIFF_LOW] ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] Date Time Of Last Edit: 2021-08-30 20:26:31
[2021-08-31 14:56:27] |
John - SC Support - Posts: 38280 |
Also refer to the following for more general information on how to access the Volume at Price data so you can do whatever you want with the data: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
