Date/Time: Fri, 28 Feb 2025 18:31:47 +0000
Numbers bar indicator was not able to display values
View Count: 496
[2021-08-30 16:39:07]
User14410 - Posts: 38
Hi, I have just restarted my subscription today and when I tried to apply Number bar indicator onto Emini futures, I found that the bars are empty without any bid/ask trade volume. May I ask where did I go wrong?
[2021-08-30 16:41:15]
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-08-31 01:40:43]
Hi, thank you for the explanation and I have managed to visualize the values on the 15-mins intraday bar. But another problem I found is that I am not able to display using historical daily bar, and is that normal because of its historical nature?
[2021-08-31 15:28:22]
John - SC Support - Posts: 38280
Correct. The Numbers Bars does not work on historical daily data. Refer to the information here:
Numbers Bars: Introduction
