Date/Time: Fri, 28 Feb 2025 18:04:04 +0000
Denali feed, Rithmic Direct DTC, limited historical data
View Count: 554
[2021-08-30 12:05:53]
User492498 - Posts: 13
Since switching to Rithmic Direct DTC (orderrouting) my historical data charts are showing limited data.
How to correct this issue?
[2021-08-30 15:16:01]
Make sure you are running the current version of Sierra Chart. Update instructions:
You should be getting the data from the Denali Exchange Data Feed.
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-08-31 07:22:45]
Software version: 2299 64-bit | 2021-08-31 03:17:34.883
Primary Thread ID: 11968 | 2021-08-31 03:17:34.883
Usage end date: 2021-12-30 | 2021-08-31 03:17:34.883
Enabled for: Advanced Features 2. | 2021-08-31 03:17:34.883
Enabled for: Sierra Chart Historical Data Service. | 2021-08-31 03:17:34.883
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-31 03:17:34.883
Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-31 03:17:34.883
Enabled for exchange2: CME (Trading Account Required) | 2021-08-31 03:17:34.883
Enabled for exchange2: CBOT (Trading Account Required) | 2021-08-31 03:17:34.883
Enabled for exchange2: COMEX (Trading Account Required) | 2021-08-31 03:17:34.883
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-08-31 03:17:34.883
Enabled for exchange2: EUREX EOBI | 2021-08-31 03:17:34.883
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-31 03:17:34.883
Current selected Data/Trading service: DTC - Sub Instance | 2021-08-31 03:17:34.883
Custom symbol settings values: disabled | 2021-08-31 03:17:34.883
Chart Update Interval: 500 | 2021-08-31 03:17:34.883
Intraday Data Storage Time Unit: 0 | 2021-08-31 03:17:34.883
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-08-31 03:17:34.883
2021-08-31 07:17:34 Local computer time in UTC | 2021-08-31 03:17:34.883
2021-08-31 03:17:34 Local computer time in SC Time Zone | 2021-08-31 03:17:34.883
2021-08-31 07:15:35 Server time in UTC | 2021-08-31 03:17:34.883
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-08-31 03:17:34.883
Program path: C:\SierraChart2\SierraChartInstance_4\ | 2021-08-31 03:17:34.883
Data Files path: C:\SierraChart2\SierraChartInstance_4\Data\ | 2021-08-31 03:17:34.883
OS Version Number: 10.0 | 2021-08-31 03:17:34.884
Locale Setting: C | 2021-08-31 03:17:34.884
DLLs: sst_FreeBundle_64.dll, sst_projection_64.dll, UserContributedStudies_64.dll | 2021-08-31 03:17:34.884
Allowed protected custom studies: SST_FreeBundle, SST_Projection, zyp_download_free | 2021-08-31 03:17:34.884
ESU1.CME Daily #1 | Reloading chart. | 2021-08-31 03:18:08.423
ESU1.CME [CV] Daily #1 | Reloading chart. | 2021-08-31 03:18:22.175
Unable to determine transition date based on volume from files: ESU8.CME.dly, ESZ8.CME.dly | 2021-08-31 03:18:22.239
The ESZ8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESZ8.CME.dly, ESH9.CME.dly | 2021-08-31 03:18:22.239
The ESH9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESH9.CME.dly, ESM9.CME.dly | 2021-08-31 03:18:22.239
The ESM9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESM9.CME.dly, ESU9.CME.dly | 2021-08-31 03:18:22.239
The ESU9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESU9.CME.dly, ESZ9.CME.dly | 2021-08-31 03:18:22.239
The ESZ9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESZ9.CME.dly, ESH0.CME.dly | 2021-08-31 03:18:22.239
The ESH0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESH0.CME.dly, ESM0.CME.dly | 2021-08-31 03:18:22.239
The ESM0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESM0.CME.dly, ESU0.CME.dly | 2021-08-31 03:18:22.239
The ESU0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.239
Unable to determine transition date based on volume from files: ESU0.CME.dly, ESZ0.CME.dly | 2021-08-31 03:18:22.240
The ESZ0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:22.240
ESU1.CME [CV] Daily #1 | Reloading chart. | 2021-08-31 03:18:30.477
ESU1.CME [CV] Daily #1 | Limiting the number of years to load data for 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-08-31 03:18:30.477
ESU1.CME [CV] Daily #1 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-08-31 03:18:30.477
Unable to determine transition date based on volume from files: ESU6.CME.dly, ESZ6.CME.dly | 2021-08-31 03:18:30.547
The ESZ6.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESZ6.CME.dly, ESH7.CME.dly | 2021-08-31 03:18:30.547
The ESH7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESH7.CME.dly, ESM7.CME.dly | 2021-08-31 03:18:30.547
The ESM7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESM7.CME.dly, ESU7.CME.dly | 2021-08-31 03:18:30.547
The ESU7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESU7.CME.dly, ESZ7.CME.dly | 2021-08-31 03:18:30.547
The ESZ7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESZ7.CME.dly, ESH8.CME.dly | 2021-08-31 03:18:30.547
The ESH8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESH8.CME.dly, ESM8.CME.dly | 2021-08-31 03:18:30.547
The ESM8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESM8.CME.dly, ESU8.CME.dly | 2021-08-31 03:18:30.547
The ESU8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.547
Unable to determine transition date based on volume from files: ESU8.CME.dly, ESZ8.CME.dly | 2021-08-31 03:18:30.548
The ESZ8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESZ8.CME.dly, ESH9.CME.dly | 2021-08-31 03:18:30.548
The ESH9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESH9.CME.dly, ESM9.CME.dly | 2021-08-31 03:18:30.548
The ESM9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESM9.CME.dly, ESU9.CME.dly | 2021-08-31 03:18:30.548
The ESU9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESU9.CME.dly, ESZ9.CME.dly | 2021-08-31 03:18:30.548
The ESZ9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESZ9.CME.dly, ESH0.CME.dly | 2021-08-31 03:18:30.548
The ESH0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESH0.CME.dly, ESM0.CME.dly | 2021-08-31 03:18:30.548
The ESM0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESM0.CME.dly, ESU0.CME.dly | 2021-08-31 03:18:30.548
The ESU0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.548
Unable to determine transition date based on volume from files: ESU0.CME.dly, ESZ0.CME.dly | 2021-08-31 03:18:30.549
The ESZ0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:30.549
Added historical Daily data request for ESH1.CME to the queue. | 2021-08-31 03:18:55.661
Triggering next historical data download in queue. | 2021-08-31 03:18:55.661
Added historical Daily data request for ESM1.CME to the queue. | 2021-08-31 03:18:55.661
Added historical Daily data request for ESU1.CME to the queue. | 2021-08-31 03:18:55.661
HD Request # 13 | Downloading Historical Daily chart data for ESH1.CME. Starting date: 1971-08-31. Service: DTCSubInstance | 2021-08-31 03:18:55.661
HD Request # 13 | Using server: 127.0.0.1 port 11098 | 2021-08-31 03:18:55.661
Socket (2) | Creating socket. | 2021-08-31 03:18:55.662
Socket (2) | New receive buffer size: 5242880 | 2021-08-31 03:18:55.662
Socket (2) | Connecting to IP: 127.0.0.1. | 2021-08-31 03:18:55.662
HD Request # 13 | Setting DTC encoding to Binary VLS | 2021-08-31 03:18:55.670
HD Request # 13 | Sending historical data logon request message. | 2021-08-31 03:18:55.670
HD Request # 13 | Requesting historical Daily data starting at 1971-08-31. | 2021-08-31 03:18:55.671
HD Request # 13 | Data is being downloaded from a remote source. Download will start when this is done. | 2021-08-31 03:18:55.671
HD Request # 13 | Decompressing data. | 2021-08-31 03:18:56.669
HD Request # 13 | Receiving historical Daily data for ESH1.CME starting at 2019-12-09 | 2021-08-31 03:18:56.672
HD Request # 13 | Writing historical Daily data to the file ESH1.CME.dly | 2021-08-31 03:18:56.673
Socket (2) | CloseSocket call. | 2021-08-31 03:18:56.674
Socket (2) | Shutdown started. Waiting for graceful close. | 2021-08-31 03:18:56.674
Historical data download thread signaled to stop. | 2021-08-31 03:18:56.674
HD Request # 13 | Received 322 Daily data records from 2019-12-09 00:00:00 to 2021-03-19 00:00:00 (467.0 days) and wrote 322 records for ESH1.CME | 2021-08-31 03:18:56.674
HD Request # 13 | Completion time: 1s | 2021-08-31 03:18:56.674
HD Request # 13 | Daily data download complete for ESH1.CME. Unique request ID: 13 | 2021-08-31 03:18:56.674
Removing historical data download ID 13. | 2021-08-31 03:18:56.674
Triggering next historical data download in queue. | 2021-08-31 03:18:56.675
HD Request # 14 | Downloading Historical Daily chart data for ESM1.CME. Starting date: 1971-08-31. Service: DTCSubInstance | 2021-08-31 03:18:56.675
HD Request # 14 | Using server: 127.0.0.1 port 11098 | 2021-08-31 03:18:56.676
Socket (3) | Creating socket. | 2021-08-31 03:18:56.676
Socket (3) | New receive buffer size: 5242880 | 2021-08-31 03:18:56.676
Socket (3) | Connecting to IP: 127.0.0.1. | 2021-08-31 03:18:56.676
Socket (2) | Socket gracefully closed by remote side. | 2021-08-31 03:18:56.676
Socket (2) | Closed. | 2021-08-31 03:18:56.676
HD Request # 14 | Setting DTC encoding to Binary VLS | 2021-08-31 03:18:56.686
HD Request # 14 | Sending historical data logon request message. | 2021-08-31 03:18:56.686
HD Request # 14 | Requesting historical Daily data starting at 1971-08-31. | 2021-08-31 03:18:56.687
HD Request # 14 | Data is being downloaded from a remote source. Download will start when this is done. | 2021-08-31 03:18:56.687
HD Request # 14 | Decompressing data. | 2021-08-31 03:18:57.687
HD Request # 14 | Receiving historical Daily data for ESM1.CME starting at 2020-03-09 | 2021-08-31 03:18:57.690
HD Request # 14 | Writing historical Daily data to the file ESM1.CME.dly | 2021-08-31 03:18:57.691
Socket (3) | CloseSocket call. | 2021-08-31 03:18:57.692
Socket (3) | Shutdown started. Waiting for graceful close. | 2021-08-31 03:18:57.692
Historical data download thread signaled to stop. | 2021-08-31 03:18:57.692
HD Request # 14 | Received 324 Daily data records from 2020-03-09 00:00:00 to 2021-06-18 00:00:00 (467.0 days) and wrote 324 records for ESM1.CME | 2021-08-31 03:18:57.692
HD Request # 14 | Completion time: 1s | 2021-08-31 03:18:57.692
HD Request # 14 | Daily data download complete for ESM1.CME. Unique request ID: 14 | 2021-08-31 03:18:57.692
Removing historical data download ID 14. | 2021-08-31 03:18:57.692
Triggering next historical data download in queue. | 2021-08-31 03:18:57.693
HD Request # 15 | Downloading Historical Daily chart data for ESU1.CME. Starting date: 1971-08-31. Service: DTCSubInstance | 2021-08-31 03:18:57.693
Socket (3) | Socket gracefully closed by remote side. | 2021-08-31 03:18:57.694
HD Request # 15 | Using server: 127.0.0.1 port 11098 | 2021-08-31 03:18:57.694
Socket (3) | Closed. | 2021-08-31 03:18:57.694
Socket (2) | Creating socket. | 2021-08-31 03:18:57.694
Socket (2) | New receive buffer size: 5242880 | 2021-08-31 03:18:57.694
Socket (2) | Connecting to IP: 127.0.0.1. | 2021-08-31 03:18:57.694
HD Request # 15 | Setting DTC encoding to Binary VLS | 2021-08-31 03:18:57.706
HD Request # 15 | Sending historical data logon request message. | 2021-08-31 03:18:57.706
HD Request # 15 | Requesting historical Daily data starting at 1971-08-31. | 2021-08-31 03:18:57.706
HD Request # 15 | Data is being downloaded from a remote source. Download will start when this is done. | 2021-08-31 03:18:57.707
HD Request # 15 | Decompressing data. | 2021-08-31 03:18:58.705
HD Request # 15 | Receiving historical Daily data for ESU1.CME starting at 2020-06-08 | 2021-08-31 03:18:58.708
HD Request # 15 | Writing historical Daily data to the file ESU1.CME.dly | 2021-08-31 03:18:58.708
Socket (2) | CloseSocket call. | 2021-08-31 03:18:58.710
Socket (2) | Shutdown started. Waiting for graceful close. | 2021-08-31 03:18:58.710
Historical data download thread signaled to stop. | 2021-08-31 03:18:58.710
HD Request # 15 | Received 312 Daily data records from 2020-06-08 00:00:00 to 2021-08-31 00:00:00 (450.0 days) and wrote 312 records for ESU1.CME | 2021-08-31 03:18:58.710
HD Request # 15 | Completion time: 1s | 2021-08-31 03:18:58.710
HD Request # 15 | Daily data download complete for ESU1.CME. Unique request ID: 15 | 2021-08-31 03:18:58.710
Removing historical data download ID 15. | 2021-08-31 03:18:58.710
Triggering next historical data download in queue. | 2021-08-31 03:18:58.710
Socket (2) | Socket gracefully closed by remote side. | 2021-08-31 03:18:58.710
Socket (2) | Closed. | 2021-08-31 03:18:58.710
No download requests in the queue to start downloads for. | 2021-08-31 03:18:58.711
ESU1.CME [CV] Daily #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-08-31 03:18:58.967
ESU1.CME [CV] Daily #1 | Reloading chart. | 2021-08-31 03:18:58.969
Unable to determine transition date based on volume from files: ESU6.CME.dly, ESZ6.CME.dly | 2021-08-31 03:18:58.970
The ESZ6.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.970
Unable to determine transition date based on volume from files: ESZ6.CME.dly, ESH7.CME.dly | 2021-08-31 03:18:58.970
The ESH7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.970
Unable to determine transition date based on volume from files: ESH7.CME.dly, ESM7.CME.dly | 2021-08-31 03:18:58.970
The ESM7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.970
Unable to determine transition date based on volume from files: ESM7.CME.dly, ESU7.CME.dly | 2021-08-31 03:18:58.970
The ESU7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.970
Unable to determine transition date based on volume from files: ESU7.CME.dly, ESZ7.CME.dly | 2021-08-31 03:18:58.970
The ESZ7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.970
Unable to determine transition date based on volume from files: ESZ7.CME.dly, ESH8.CME.dly | 2021-08-31 03:18:58.971
The ESH8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.971
Unable to determine transition date based on volume from files: ESH8.CME.dly, ESM8.CME.dly | 2021-08-31 03:18:58.971
The ESM8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.971
Unable to determine transition date based on volume from files: ESM8.CME.dly, ESU8.CME.dly | 2021-08-31 03:18:58.971
The ESU8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.971
Unable to determine transition date based on volume from files: ESU8.CME.dly, ESZ8.CME.dly | 2021-08-31 03:18:58.971
The ESZ8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.971
Unable to determine transition date based on volume from files: ESZ8.CME.dly, ESH9.CME.dly | 2021-08-31 03:18:58.971
The ESH9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.971
Unable to determine transition date based on volume from files: ESH9.CME.dly, ESM9.CME.dly | 2021-08-31 03:18:58.971
The ESM9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.971
Unable to determine transition date based on volume from files: ESM9.CME.dly, ESU9.CME.dly | 2021-08-31 03:18:58.972
The ESU9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.972
Unable to determine transition date based on volume from files: ESU9.CME.dly, ESZ9.CME.dly | 2021-08-31 03:18:58.972
The ESZ9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.972
Unable to determine transition date based on volume from files: ESZ9.CME.dly, ESH0.CME.dly | 2021-08-31 03:18:58.972
The ESH0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.972
Unable to determine transition date based on volume from files: ESH0.CME.dly, ESM0.CME.dly | 2021-08-31 03:18:58.972
The ESM0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.972
Unable to determine transition date based on volume from files: ESM0.CME.dly, ESU0.CME.dly | 2021-08-31 03:18:58.972
The ESU0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.972
Unable to determine transition date based on volume from files: ESU0.CME.dly, ESZ0.CME.dly | 2021-08-31 03:18:58.972
The ESZ0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:58.972
ESU1.CME [CV] Daily #1 | Reloading chart. | 2021-08-31 03:18:59.463
ESU1.CME [CV] Daily #1 | Limiting the number of years to load data for 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-08-31 03:18:59.463
ESU1.CME [CV] Daily #1 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol. | 2021-08-31 03:18:59.463
Unable to determine transition date based on volume from files: ESU6.CME.dly, ESZ6.CME.dly | 2021-08-31 03:18:59.532
The ESZ6.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.532
Unable to determine transition date based on volume from files: ESZ6.CME.dly, ESH7.CME.dly | 2021-08-31 03:18:59.532
The ESH7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.532
Unable to determine transition date based on volume from files: ESH7.CME.dly, ESM7.CME.dly | 2021-08-31 03:18:59.532
The ESM7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.532
Unable to determine transition date based on volume from files: ESM7.CME.dly, ESU7.CME.dly | 2021-08-31 03:18:59.532
The ESU7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.532
Unable to determine transition date based on volume from files: ESU7.CME.dly, ESZ7.CME.dly | 2021-08-31 03:18:59.532
The ESZ7.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.532
Unable to determine transition date based on volume from files: ESZ7.CME.dly, ESH8.CME.dly | 2021-08-31 03:18:59.533
The ESH8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESH8.CME.dly, ESM8.CME.dly | 2021-08-31 03:18:59.533
The ESM8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESM8.CME.dly, ESU8.CME.dly | 2021-08-31 03:18:59.533
The ESU8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESU8.CME.dly, ESZ8.CME.dly | 2021-08-31 03:18:59.533
The ESZ8.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESZ8.CME.dly, ESH9.CME.dly | 2021-08-31 03:18:59.533
The ESH9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESH9.CME.dly, ESM9.CME.dly | 2021-08-31 03:18:59.533
The ESM9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESM9.CME.dly, ESU9.CME.dly | 2021-08-31 03:18:59.533
The ESU9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESU9.CME.dly, ESZ9.CME.dly | 2021-08-31 03:18:59.533
The ESZ9.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.533
Unable to determine transition date based on volume from files: ESZ9.CME.dly, ESH0.CME.dly | 2021-08-31 03:18:59.534
The ESH0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.534
Unable to determine transition date based on volume from files: ESH0.CME.dly, ESM0.CME.dly | 2021-08-31 03:18:59.534
The ESM0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.534
Unable to determine transition date based on volume from files: ESM0.CME.dly, ESU0.CME.dly | 2021-08-31 03:18:59.534
The ESU0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.534
Unable to determine transition date based on volume from files: ESU0.CME.dly, ESZ0.CME.dly | 2021-08-31 03:18:59.534
The ESZ0.CME.dly symbol may not be the active contract month. | 2021-08-31 03:18:59.534
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-08-31 03:19:22.656
DTC Client socket (1) | CloseSocket call. | 2021-08-31 03:19:22.656
Rithmic Direct - DTC | Disconnected. | 2021-08-31 03:19:22.656
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-08-31 03:19:22.656
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-31 03:19:22.657
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-08-31 03:19:22.657
DTC Client socket (1) | Closed. | 2021-08-31 03:19:22.657
Rithmic Direct - DTC | Connecting to the server 127.0.0.1. Port 11099 | 2021-08-31 03:19:24.654
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-08-31 03:19:24.654
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-08-31 03:19:24.654
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-08-31 03:19:24.654
Rithmic Direct - DTC | Network connection to server complete. | 2021-08-31 03:19:24.656
Rithmic Direct - DTC | Starting socket receive thread. | 2021-08-31 03:19:24.656
Rithmic Direct - DTC | Sending encoding request to server: Binary VLS. Compression: none | 2021-08-31 03:19:24.657
Rithmic Direct - DTC | Setting DTC encoding to Binary VLS | 2021-08-31 03:19:24.661
Rithmic Direct - DTC | Sending logon request message. | 2021-08-31 03:19:24.661
Rithmic Direct - DTC | Received logon response. | 2021-08-31 03:19:24.664
Rithmic Direct - DTC | Server Name: SC DTC Server. Build=38697M. | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | Successfully connected. Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading. | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | Trading is supported. | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | Order cancel and replace is supported. | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | OCO Orders supported. | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | Bracket Orders supported. | 2021-08-31 03:19:24.665
Rithmic Direct - DTC | Connected to server complete. | 2021-08-31 03:19:24.665
Triggering next historical data download in queue. | 2021-08-31 03:19:24.665
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 3. | 2021-08-31 03:19:24.666
No download requests in the queue to start downloads for. | 2021-08-31 03:19:24.666
Symbol settings MD5 received. Request ID: 3. | 2021-08-31 03:19:24.919
Symbol settings are up-to-date for rithmic_v2.trading. | 2021-08-31 03:19:24.919
Rithmic Direct - DTC | Starting real-time market data updates for: ESU1.CME. ID: 1 Service code: rithmic.trading | 2021-08-31 03:19:24.963
Rithmic Direct - DTC | Requesting security definition data for: ESU1.CME. ID: 1 | 2021-08-31 03:19:24.963
Rithmic Direct - DTC | Received security definition for symbol ESU1.CME | 2021-08-31 03:19:24.972
[2021-08-31 07:26:33]
We need to understand exactly the symbol of the chart and the chart type.
Provide an image of the chart or Trade DOM, by following these instructions:
[2021-08-31 07:30:46]
http://www.sierrachart.com/image.php?Image=1630395033414.png
[2021-08-31 10:24:17]
For long-term continuous futures contract charts, you need to use this service;
You cannot use the Rithmic Service due to the symbols.
You will need to install a separate installation of Sierra Chart.
Date Time Of Last Edit: 2021-08-31 10:24:26
[2021-08-31 10:45:26]
But i'm subscribed to Denali Real-Time Exchange Data Feed and only use Rithmic for order routing.
"The Denali Exchange Data Feed provides real-time and historical data for the CME, CBOT, NYMEX, COMEX, and EUREX exchanges."
What you propose is delayed historical data.
[2021-08-31 12:59:58]
For long-term Continuous Futures Contract charts the only reliable way to do these, is to use a separate installation of Sierra Chart set to use SC Data-All Services. In your case the data will still be real-time.
