Date/Time: Fri, 28 Feb 2025 18:51:20 +0000
Denali feed, Rithmic Direct DTC Eurostoxx 50 offer depth not showing correctly in DOM
View Count: 550
[2021-08-30 10:02:26]
User492498 - Posts: 13
Offer depth on DOM is squeezed on 2 lines.
And volume at price is not showing correctly, not showing volume at 0.5 intervals.
Also the tick size of 0.5 is not applied automatically in the chart settings.
Price increments of 0.5 points are not showing.
http://www.sierrachart.com/image.php?Image=1630317267940.png
[2021-08-30 10:46:08]
After that follow these settings to apply the updated settings to the chart:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
