Date/Time: Mon, 16 Sep 2024 19:08:05 +0000
Manual Rollover
View Count: 1101
[2014-03-22 12:39:33] |
maxima120 - Posts: 144 |
Hi I quite like the rollover feature. But would like to have a menu item (for example - Edit or Edit -> Symbol Settings) to be able to rollover any symbol to any symbol within the opened chartbooks. Same UI as you have for a chart rollover only I can open it any time (not waiting till the yellow banner on a chart appears prompting for the rollover). And in the left dropdown I want see all symbols currently in all opened chartbooks. Thank you |
[2014-03-23 20:04:18] |
Have a look at, if you have not already, Chart >> Perform Futures Symbol Rollover.
[2014-03-24 22:22:53] |
sorry. thats exactly what I needed. somehow missed it. thank you |
