Date/Time: Fri, 28 Feb 2025 18:42:29 +0000
Overlay of Candlesticks
View Count: 586
[2021-08-30 07:27:11] |
Manerva Funding Financial - Posts: 16 |
When I overlay the candlesticks the numbers are white for and i can't read them how to you change the numbers
[2021-08-30 15:45:41] |
The text color can be controlled with these Numbers Bars Input settings: Numbers Bars: Use Separate Colors for Text Coloring Method (Starts with Use Separate Colors for Text Coloring Method) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-30 15:45:58
