Date/Time: Fri, 28 Feb 2025 18:42:55 +0000
Duplicate Chart to Another Chartbook
View Count: 493
[2021-08-29 14:29:36] |
User696540 - Posts: 28 |
Hello, I can no longer Duplicate a Chart to another opened Chartbook. The only Chartbook in the list is the one that I'm in. None of the other Chartbooks are listed....hence there is no option to pick one to copy the chart to. Thanks |
[2021-08-29 22:38:24] |
Tonkadad - Posts: 235 |
See if opening the destination chartbook prior to trying too duplicate it, populates the dropdown list.
Date Time Of Last Edit: 2021-08-29 22:38:54
[2021-08-31 14:03:00] |
John - SC Support - Posts: 38280 |
We have had this question a few times lately, but we think this is just a misunderstanding of how to use the new windows. Refer to the information in this section in particular for how to use that Item List to select the Chartbook you want to copy to: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
