Date/Time: Fri, 28 Feb 2025 18:48:31 +0000
Chart replay w/IQfeed -
View Count: 532
[2021-08-29 01:57:15] |
HeyUgly - Posts: 251 |
hello trying to figure out whats going on, when using the playback which ive used a million times, with IQfeed data on replay , settings set to "1" which is always realtime playback, 'the data flows back on replays exactly in 1 second movements, which is completely wrong any idea whats going on? i chage it to "2" and its much much faster, not sure how to get settings to just playback in realtime as what ive used a million times before with Sierra data feed has always been fine. When switching it to 2, it just seems like its double the time as 1, with no real-time flow of orders, because regular orderflow doesn't come in perfectly like that thanks in advance! Date Time Of Last Edit: 2021-08-29 02:15:36
[2021-08-30 07:38:18] |
We very much recommend using the Sierra Chart provided data feeds instead of IQ Feed: Real-Time Exchange Data Feeds Available From Sierra Chart We do not provide technical help for IQ feed data issues. It is also possible there is no millisecond time stamping support for IQ Feed. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Also refer to: DTN IQ Feed Data Service: Tick Data Limitation during Primary Session Hours Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-30 07:39:30
[2021-08-31 19:28:54] |
no problem , thought id ask, i would happily go back if you could develop an option chain for stocks! it would be kick ass!!
