Date/Time: Tue, 26 Nov 2024 00:21:54 +0000
[User Discussion] - -
View Count: 1057
[2014-03-22 11:57:42] |
User90848 - Posts: 57 |
Date Time Of Last Edit: 2015-04-29 14:00:04
[2014-03-23 04:21:50] |
And how do you expect us to do that? Review the documentation for the study you are using. Based upon how the study works, the Input settings that you have set for the study and the data in the charts being referenced by the study, explain the calculations. And explain why the study is not giving a correct result. Also, your study is not even referencing an Intraday chart so a comparison to it is irrelevant. In general, the support request is outside the scope of our support. It is way too much of an expectation to expect us to figure this out for you. It is your responsibility to do this. And if you think there is something wrong with the way to study is working, then explain why. We will not provide an answer until we have 100% clear information presented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-23 04:24:20
