Date/Time: Fri, 28 Feb 2025 18:18:22 +0000
Narrow footprint candle size
View Count: 774
[2021-08-28 10:25:55]
Alp İpekçiler - Posts: 1
I want my candles narrower like the one on fp2.jpg, while mine is like fp1.jpg. I tried changing the numbers at (Global Settings > Graphic Settings - Global > Other > Candlestick Width %) but nothing changed.
imagefp1.png / V - Attached On 2021-08-28 10:22:58 UTC - Size: 5.9 KB - 222 views
imagefp2.png / V - Attached On 2021-08-28 10:23:04 UTC - Size: 35.37 KB - 211 views
[2021-08-28 10:52:37]
User146848 - Posts: 124
Try "arrow down" on your keybord.
[2021-08-28 14:44:11]
John - SC Support - Posts: 38280
As noted by User146848, your issue is just related to the scaling of your chart, not the width settings. You just need to compress your chart down to get the data to show more like what you want. Refer to the following regarding scaling Numbers Bars charts:
Numbers Bars: Scaling a Numbers Bars Chart
