Date/Time: Fri, 28 Feb 2025 18:16:10 +0000
BitMEX TLS 1.2 upgrade support
View Count: 480
[2021-08-27 11:48:48] |
User517260 - Posts: 97 |
Dear Support, since 1st September 2021 BitMEX requires all users to move to Transport Layer Security (TLS) 1.2. Which Version of SierraChart I have to use to avoid problems with BitMEX? Thanks! Waiting for your reply, Alex. |
[2021-08-27 11:53:35] |
This is already supported.
[2021-08-27 12:12:23] |
I use old 2171 version because some of dll are compiled for that version and don't work with new versions. So, I doubt about version 2171 had support of TLS1.2. If not - I will have problems. Could you advise me something?
[2021-08-27 12:38:17] |
I upgraded SierraChart to latest version and my old dll is working ok, so problem is solved, thanks a lot!
