Date/Time: Fri, 28 Feb 2025 18:20:34 +0000
Stop orders slippage
View Count: 493
[2021-08-27 10:15:58] |
User645832 - Posts: 99 |
Please advise how slippage on stop orders can be controlled, e.g. I'm short /GC at 1783 with a stop at 1785, then news comes out and /GC shoots 30 points instantly. What usually happens is my stop gets filled at a higher price (X2 X3 times) then my original stop. Is there any way to control the slippage and create a stop order than will not get filled unless the price is in x% range within the stop price? Thank you |
[2021-08-27 16:52:49] |
Sierra_Chart Engineering - Posts: 18602 |
Yes. You will want to use a Stop-Limit order: Order Types: Stop-Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
