Date/Time: Fri, 28 Feb 2025 18:12:48 +0000
Denali exchange data feed with IB trading possibility
View Count: 637
[2021-08-27 07:14:06] |
User58776 - Posts: 18 |
Hello, I would like to have real time data for trading the ES futures. As I use number bars and cumulative delta, I prefer the denali exchange feed. However, I do would like to connect my interactive brokers account so I can trade from the Sierrachart. How do I set up this? thanks in advance best regards Jeroen |
[2021-08-27 15:01:16] |
John - SC Support - Posts: 38280 |
First, you would follow these instructions to get your Sierra Chart connected to your Interactive Brokers account: Interactive Brokers Trading Service: Setup Instructions Then you would go through these instructions to ensure that you are fully setup to get your data from us (most likely there is nothing you would need to change, but just to be sure go through all of these instructions): Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services And finally, if you were not previously connected to Interactive Brokers, then you will want to open your Chartbooks and select Edit >> Translate Symbols to Current Service in order to change the symbols to IB symbols. Refer to the information here: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
