Date/Time: Fri, 28 Feb 2025 18:31:31 +0000
DOM Chart not displaying P&L and Position Correctly
View Count: 492
[2021-08-27 04:10:15] |
Kylek1485 - Posts: 6 |
Hi, I'm currently in a short position at 4475.50, but my DOM chart is showing my position at 4469.50. I don't know how to fix this. I've tried charts, advance settings 2, load current day fills only, and that didn't help. If I click on trade, and then try to unclick "Show position and fills" it will momentarily show the correct position but then it goes right back to the wrong position and it automatically applies the checkmark back to "Show position and fills" I've tried disconnecting the data and reconnecting and that did not help either. |
[2021-08-27 07:09:04] |
This is a question about the position average price. Therefore, refer to: Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
