Date/Time: Fri, 28 Feb 2025 18:01:14 +0000
unable to connect sub instance
View Count: 433
[2021-08-27 01:08:53]
User591259 - Posts: 2
Hi, I have followed the recommended settings but when I try to connect my second computer ( the sub instance) I get the attached error (connect event error. windows error code 10060. A connection failed because the connected third party did not respond properly.
Looks like I missed something in the setup procedure but I cant work out what.
Please assist.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=54040
[2021-08-27 02:46:16]
The firewall on the computer you are connecting to, needs to be allowed to allow the connection . The port also needs to be forwarded through the router if there is one.
Date Time Of Last Edit: 2021-08-27 02:47:05
