Date/Time: Tue, 26 Nov 2024 00:39:26 +0000
data in number bar
View Count: 964
[2014-03-22 10:56:34] |
User59284 - Posts: 4 |
Hello, as you can see in the picture there is no data in number bars studies thanks |
Capture foot print.PNG / V - Attached On 2014-03-22 10:56:17 UTC - Size: 143.79 KB - 345 views |
[2014-03-23 05:19:04] |
Refer to the documentation about this here: https://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ServicesThatSupportBVandAV Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
