Date/Time: Fri, 28 Feb 2025 18:01:39 +0000
second computer
View Count: 494
[2021-08-26 19:56:25] |
User976507 - Posts: 1 |
Hi and thx for still being there. Presently trading live on the Bookmap platform mainly the e-minis, using Rithmic mbo CME data. I need to start using your TPO volume profile charts again on another computer with large monitors. No trading required, only need the live charts. Any feed , even simulation would work as long as I can get something comparable to ES and NQ e-mini markets. What is the best way to get something to at least try?
[2021-08-27 11:40:24] |
Use this data feed: Delayed Exchange Data Feed Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-27 11:41:23
