Date/Time: Fri, 28 Feb 2025 18:27:04 +0000
New market depth window - change colours
View Count: 760
[2021-08-26 14:54:30]
HeyUgly - Posts: 251
hello
i launch a market depth window, the blue or purple is impossible to read anything in it on the ask side, i cant find the setting in chart graphics settings to change it, can you guide me to where that is? thank you!
imageCapture7.PNG / V - Attached On 2021-08-26 14:54:19 UTC - Size: 8.58 KB - 215 views
[2021-08-27 14:00:55]
John - SC Support - Posts: 38280
The colors are controlled by the items within Graphics Settings that start with Market Depth:. Such as Market Depth: Bid Gradient Start Color and Market Depth: Bid Gradient End Color.
We will get the documentation updated for these as soon as we can.
[2021-08-27 17:51:05]
Also refer to:
File Menu: Open Market Depth Window (File)
