Date/Time: Fri, 28 Feb 2025 18:12:48 +0000
Duplicate Chart to Another Chartbook
View Count: 871
[2021-08-26 13:38:02] |
User696540 - Posts: 28 |
Hello, It seems this is not working property with ver 2262. The only chartbook in the list is the one you are in. The other chartbooks are not in the list. |
[2021-08-26 18:17:07] |
Tonkadad - Posts: 235 |
I noticed issues with that also. Using the latest version of SC. |
[2021-08-27 01:56:48] |
Acro - Posts: 442 |
Not working for me either in 2299
[2021-08-27 02:50:15] |
We do not see any problem with this. In the Duplicate Chart window, the list of Chartbooks is a drop-down list. You need to left click twice on that list to display it. Refer to: Settings Windows Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-27 04:18:09] |
I know it is a drop down list, it doesn't show all of the chartbooks.
[2021-08-27 06:53:51] |
Are those Chartbooks currently open?
[2021-08-27 14:54:02] |
John - SC Support - Posts: 38280 |
Also, refer to the following documentation for how to use that particular item in the new windows: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
