Date/Time: Fri, 28 Feb 2025 18:43:24 +0000
[User Discussion] - Initial Balance - Lines will not display
View Count: 460
[2021-08-25 18:20:51]
User570216 - Posts: 6
I have an initial balance study set for the 1st hour of the trading session but my lines and labels will not display. I have my colors for the lines chosen and the labels, but they are just not showing up on my chart. I have gone though all of the settings multiple times and can’t figure out what I’m missing. Can someone refer me to the proper setting to make sure they appear on my chart?
[2021-08-31 03:22:22]
BenjaminR - Posts: 172
Check the IB High & IB Low (SG7 & SG8), & make sure the draw style is set to something other than "Ignore". Also, check the boxes for 'name label' & 'value label' if you want those to appear.
If you don't see anything, be sure that the "Hide" box in the "Studies to Graph" window of the "Chart Studies" dialogue is unchecked.
The default settings should cause 3 lines to appear: High, Low, & Mid.
Hope that helps you.
