Date/Time: Fri, 28 Feb 2025 13:27:23 +0000
Position line disappeared
View Count: 451
[2021-08-25 18:14:43] |
SpearChucker - Posts: 104 |
DOM says I'm flat. Chart and Open Positions say I'm still in the trade. !?! I've been in this trade for several weeks and both DOM and Chart matched. Just checked the DOM, and the position looks closed, but the tgt and stop are still there.
[2021-08-25 18:28:47] |
This potentially can be a problem with a spread position, held for the long term. Set this setting, to a date earlier than the position was created: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-25 18:28:58
