Date/Time: Fri, 28 Feb 2025 18:50:36 +0000
CME Data
View Count: 611
[2021-08-25 16:25:45]
Sami2 - Posts: 11
Hi guys, thank you so much for the hard work you are putting in order to came up with this wonderful platform.
I got the EUREX data and didn't know it was included in the denali data I already have. Is there anything to do about it?
Also, if I get CME data as well, will I have access to real time data for futures and stocks as well?
Do you have options for stocks?
Thank you.
Date Time Of Last Edit: 2021-09-01 12:38:02
[2021-08-25 16:32:37]
First, the EUREX real-time data working properly for you? Let us know if you have any problem.
EUREX data is properly set up on your account.
CME data will provide real-time futures data from the CME. What futures trading/brokerage service do you use? For the reason why we ask this question, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges)
Real-time stock data is provided through the Sierra Chart Exchange Data Feed:
No we do not have options data for stocks.
Date Time Of Last Edit: 2021-08-25 16:32:44
[2021-08-25 18:20:03]
Sami2 - Posts: 11
I'm using AMP and CQG.
EURUX data is properly working for me.
I dont have access to historical data for CME tho.
I have the Sierra Chart data Feed but no data at all
[2021-08-25 18:29:43]
You need to activate the required CME exchange from here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed
After that:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Date Time Of Last Edit: 2021-08-25 18:30:13
[2021-08-26 12:41:46]
Sami2 - Posts: 11
Can I get a trial for the CME exchange please.
I'm also waiting for the 1st to pay for it. I don't even need the EUREX and purchased it by mistake.
Thank you
[2021-08-27 18:07:39]
Yes you can get a trial but we would recommend waiting until next week to take advantage of the full month. Otherwise the trial will end at the end of August.
When you are ready, just activate the required exchanges from here:
We deactivated EUREX from renewing on your account.
[2021-08-27 18:53:16]
SC Support - Posts: 1937
Hi Sami, we spoke yesterday, you will notice that you are now on SP12 (no longer SP11), on SP12 you can connect to CQG for Order Routing while getting (1) historical data from Denali, and (2) Real-time CME Group Futures Data from Denali (when activated).
As written above you should be waiting until the 1st of September to get the maximum time from your real-time CME Group data trial, for activating on September 1st see #3 here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME
