Date/Time: Fri, 28 Feb 2025 13:28:37 +0000
Etherum Futures - Adjust Price
View Count: 678
[2021-08-25 12:52:50]
KXRCap - Posts: 64
Dear SC, can you move the decimal in ETH futures.
You are currently quoting it as 317100.00 and it should be 3171.00
Thanks.
[2021-08-25 14:27:20]
Is this a CME symbol?
Tell us the exact symbol you are referring to.
[2021-08-25 14:52:02]
KXRCap - Posts: 64
CME:F.US.ETHU21
[2021-08-25 17:46:07]
This is resolved.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
