Date/Time: Fri, 28 Feb 2025 18:13:19 +0000
RVOL
View Count: 707
[2021-08-24 22:59:01]
MGGG - Posts: 7
Using Sierra's relative volume study, 10 days on 5-min chart, the the cumulative volume calculates a value that is in line with relative volume on other trading platform such as IRT but the relative volumes do not match? Thanks
[2021-08-27 13:24:24]
John - SC Support - Posts: 38280
Make sure you understand how the calculations are performed in each platform. The information for how the calculation is done within Sierra Chart can be found here:
Relative Volume
[2021-08-29 05:23:22]
The calculations are done correctly in Sierra Chart. We cannot help with differences. For information about how the study works, refer to:
Relative Volume
Also make sure there is sufficient data loaded in the chart through the Chart >> Chart Settings, based upon the Study Settings.
Date Time Of Last Edit: 2021-08-29 05:24:24
